EK DDC Heatsink Housing
k.3nny
Oldscool.
EK-DDC Heatsink Housing is an heatsink upgrade kit for any Laing DDC type water pump. This add-on vastly improves the cooling performance of the motor and electronics and thus prolongs the lifespan of the water pump.
EK-DDC Heatsink Housing - Nickel 19,95€
EK-DDC Heatsink Housing - Black 19,95€
his product also features vibration dampening rubber mounting system which effectively de-couples the water pump from the rest of the computer chassis.
Enclosed:
- EK-DDC Heatsink Housing
- Pre-cut thermal pad
- Mounting mechanism with vibration dampers
:eusa_clap::eusa_clap::eusa_clap::eusa_clap::eusa_clap::eusa_clap::eusa_clap:
Hightower Diepte ek ddc reservoir Waterkoeling 3
DutchChilles Combinatie Bitspower top en EK Housing voor DDC pomp Handleidingen en Installatie Tips 5
WiSK DDC pomp reparatie Handleidingen en Installatie Tips 23
Mannozels Diversen waterblokken en 1 ddc pomptop Verkocht 4
XenoMorpH Welke EK res op de EK-DDC Dual TOP V.2?? Waterkoeling 3
Sp33dFr34k Fancontroller voor Liang DDC-1RT Waterkoeling 6
P EK-UNI Holder DDC ADD-ON & EK-UNI Holder D5 HighFlow Product Suggesties en Nieuws 2
Vannos [VERKOCHT] 1xLaing DDC-1 MCP35 /1x Bitspower 5.25 Bay Reservoir Black Verkocht 3
Joren [VERKOCHT] MCP355 / DDC 18w Verkocht 7
Joren EK WB DDC X-res 100 HighFlow Product Suggesties en Nieuws 5
Arniebomba [VERKOCHT] Liang DDC-1T Plus Verkocht 3
alain-s [VERKOCHT] Pomp MCP350 + EK DDC Top V2 Verkocht 1
DGM [VERKOCHT] MCP350 + EK-DDC X-TOP Rev.2 Acetal Verkocht 4
C Downgrading DDC 355 Waterkoeling 15
T XSPC DDC Dual Bay Reservoir TWO vraagje Waterkoeling 4
arwin74 [VERKOCHT] EK-DDC X-TOP Rev.2 Plexi/Acetal Verkocht 17
Garrett [CANCELLED] EK-DDC Dual TOP V2 Verkocht 1
